Ive had to make them myself.bentwire":1zix5349 said:looks nice where did you find the mount for the supercharger
Im running a water to air intercooler that attaches to the pipe at the front of the motor, and theres not a lot of room at the back.GrantD":f0gz9cs3 said:I'm jealous...
Something that I was curious about though, is it possible for you to index your carb hat 180* and bring the tubing around the bank side of the motor. It looks like it'd be a shorter, simpler run. It does depend on the space available though.
I just sent them of to Jet Hot coatings so when they get back ill get some pics. there the ones Jet Hot dirrect supplys,I had to do a little banging and cutting, there not mandrel bent (like there add says they should be !) but there OK.Stubby":3o0k2ywu said:Sweet. 8)
I want to see some better pics of those extractors. Please!
OK, its a oval port (third generation i think) with a Yellow terra snout extention, 12 counter weight crank from Aussie EF Falcon, ballancer is 6 rid serpintine to match blower, I will be getting a blower pulley made for about a 7 to 8 psi (worried about head gasket if i go to high) 200 rods(6.27 inch) Rover stroker 4.6 forged pistons(made by KB)3.720 inch(comp. dist- 1.195),Classic inline head,oversize valves, 250 crossflow anti-pump up lifters,Crow Cam (i sent my engine specs and this is what they made me) 63689 l/c 112 is 222/230 @ .050" 280/289Broncitis":smxi5pj4 said:Can you tell us a little more about the build, is that a square or oval port m90, what will be your drive ratio and estimated boost and what are some of your internals, I'm glad to see another m90 coming up, I think you will be impressed, depending on alot of factors a 2.5.1 should put you at about 8-9 pounds, I ran mine at 2.65.1 and its a little much in the 200, gonna bring it down around 8 psi, absolutely great looking build and can't wait to hear how it runs, I'm getting to excited about another m90 build, lets not forget that great AL head that makes it all possible, compliments of classicinlines.
I have to cut o hole in the bracket were the waterpump usually goes and fit a water neck like the top radiator hose has. Im waiting till i get pulleys and belt sorted in case i need to have the hoses going the other way.Army of Six":3ut5zxrt said:thats a nice build, but im a little confused about how the electric water pump will work, i see a way for the coolant to get out of the motor but i dont see a way for the coolant to get into the motor.
also, just wonderning why you chose a supercharger rather than a turbocharger?
cheers
Cool,gravelrash":1hlrxanp said:nice work there mate. i see your in Rocky, im about to move my turbo 2v XP and family to Emerald.
