The following is a thread I created on a volvo forum, since I own one (had two but down to one now). Basically, my current car is a GLT model, which is a low pressure turbo, stock ECU runs to 5psi with a Garret 13G compressor. It's a 2.4L 5 cylinder, with a stock CR of 9.0:1. The T5 is a high pressure turbo (either Garret 15G or a6T), 10 psi stock, 2.3L 5 cylinder, and stock CR of 8.5:1. The blocks are identical. The only change is the T5 has different pistons to drop CR down, and slightly larger injectors. So with that in mind, see if you can make sense of my ramblings below. The GLT makes 190BHP and the T5 is at 236BHP.
Now, here are the compressor maps.
http://www.stealth316.com/images/td04-13g-jlspec.gif
http://www.stealth316.com/images/td04-15g-jlspec.gif
Ignore the VE lines, since that's for a different engine, just that was the only place I could easily find the compressor maps.
What I found with the 13G was this:
For 190BHP, I end up with a CFM of about 238.
At 5psi, you are around the 65% efficient mark, with making 190BHP with a compressor speed slightly under 120kRPM.
Assuming you get to 240HP with the 13G, you are actually around the 68-70% efficient mark (max is around 73%) with a compressor speed around 130kRPM, which is an increase of around 8%.
Now, with the 15G making the same power will be around 73% efficient with a compressor speed of around 115kRPM, which is about 12% less than the 13G at the same power.
The 13G was no where close to the upper operating edge of the compressor curve when operating at 240HP.
Seems to me that there should be minimal problems with the turbo. Sure, there will be slightly more heat, which will decrease the charge density some, but doesn't seem like that much.
Now, most people comment with this swap (without any dyno's) that they don't feel the power. I wonder if this is due to the nature of the smaller turbo. The T5 ECU in stock form limits the boost to 5 psi in 1st and 2nd to protect the transmission and limit wheel spin. The GLT obviously doesn't need to do this (same transmission). I wonder if it feels like less power only due to the fact the 13G turbo spools up almost instantly instead of the 15G which does have a lag and this it's like "OMGWTF going PLAID" power.
Problem is, the performance oriented volvo sites are populated by too many kids that watch F&F as reference material. The older volvo websites are full of people with no clue about cars. So I come here, to people I trust.
Also, I don't see any problems running 10psi with 9:1CR on an AL head, do you? Seems a fairly conservative thing number.
Regards
To me, the T5 ECU swap seems pretty straight forward. What confuses me is the people who say the power won't be the same as a T5. My questions revolve around that.
1) Some people mention that a 13G at 10psi and a 16T at 10 psi will not have the same power on the same engine. Now, let's neglect the temperature part of the issue. I understand that a 13G may impart some more heat since it's a smaller turbo, but I haven't looked at the compressor maps yet to see where a 2.4L engine will fall in the efficiency curves of the 13G. Let's also neglect the increased CR of the LPT engine for this argument. If we follow those assumptions...isn't 10 PSI 10 PSI? Doesn't the ECU get the reading from the MAP sensor and adjust the wastegate on the turbine side accordingly to maintain the appropriate pressure? without factoring in temperature,10PSI of air should have the same charge density, no matter the turbo compressor size, correct?
2) Now, I understand the need to upgrade the injectors. Without getting into injector sizing math, I'm sure when you add 50% more boost (6.5 to 10) you may push the continuos duty rating of the GLT injectors. Cheap insurance. But some say that without the T5 turbo, the white injectors will cause you to run rich. Again, I don't see how this is true, but maybe motronic doesn't work like Megasquirt which is the reason I ask. On MS, you program target AFRs based on a number of parameters. Mostly, RPM and either MAP or MAF. Based on those inputs, the computer looks up in the table what the target AFR is and using engine presets guesses what it should be. If it's off slightly, it reads that from the O2 sensor and makes adjustments. I can see when under WOT you will run rich, but most ECUs default to rich in WOT anyways. So, if I install white injectors with a T5 ECU, it shouldn't have any problems since the MAF and MAP are still going to report pressures and flows to the ECU which will fire the injectors that it was designed for (white). If we agree that 10PSI is 10PSI (assuming same charge temp) then the MAP and MAF readings should be identical for 13g versus 15g or 16T. Am I missing something?
When I look at it, it seems that the LPT engine with a T5 ECU, 13G, and white injectors should perform better than, or at least on par with a stock T5 car. With a faster spooling turbo, the area under the power curve should be larger. And with the .5 higher CR, you end up with a little more power.
The reason I ask this is for two reasons. I like to understand everything about my cars. I love working and building cars. I owned a 98 S70T5 from 2001-2010. In 2009, I picked up a V70 GLT to temporarily replace my wife's mustang. However, I just can't seem to get rid of this car. I love the color and I just love the 98-00 styles. Runs great and love having no car payments. But...I do long for that extra 45 HP. I like the smooth delivery of power from the GLT's 13g, but want more of it. However, since I do use this for my daily driver during the winter and some during the summer I want to keep it relitively reliable. I do have an 04 Silverado that i drive some, but the mileage for my daily commute is rough. Seems like the T5 ECU and injectors would do great. I would likely eventually upgrade to the T5 turbo to complete the swap, but just curious about the true impact of not doing it, with all the information I've read.
Regards
