65fback
As some of you may recall my water pump decided to eat itself last spring. Once I saw the crap that was in the pump I elected to pull the head to clean the water passages as much as possible and to get a general look at the condition of the top end of the engine. While the head was off I made sure to chase all bolt holes to get the crud out so I would have accurate readings with the torque wrench.
Since I've re-installed the head the engine has been leaking oil. I haven't been able to figure out where until now. At first I thought it was the valve cover gasket as oil was coating the cylinder head as well as the block. I replaced the valve cover gasket (again) this summer, resulting in no change in the leakage.
I happened to need to pull the Mustang out of the shed this week to look for some halloween decorations. While I had the car out and idling I decided to take another look. I revved the engine using the gas pedal linkage and observed. What I saw was oil weeping out the front and then get blown back my the fan, which would explain why oil has been getting up on the cylinder head.
My question is do I have to chuck the gasket and start from scratch or would going over the head with the torque wrench again be of any benefit?
