electrorc
Hey everyone, I'm back
Good news first:
The Mustang is fully street legal, and I've been driving it around a little bit. I'm enjoying it for the most part, but really wish I could get all the issues ironed out. I also don't have overheating issues anymore--she stays right around 1/2 or a bit under on the gauge now. The oil pan leak is fixed as well, courtesy of a new generic gasket. I'm also now a college grad.
The bad (I'll just list things first):
What I've done or tried:
Any suggestions on anything? Thanks!!
Good news first:
- It's still idling really rough. It's shaking and what not. Rev it to 1500 or so and it will smooth out a bit, but you can normally still feel some vibration through the gas pedal.
- It seems to have some sort of clatter or something up in the valvetrain. I'm not really sure how to describe it, but it just seemed noisy and seemed to be coming from around there. It almost seems to be worse at the back of the engine.
- I think it's missing a little. The exhaust feels very uneven if you put your hand out past it and it kind of pops.
- It hesitates or stumbles when you hit the gas while driving. When you first get on it, it won't do much of anything, but then if you just hold your foot there for a second longer it'll go.
- I just found this one today after driving it around. I happened to look underneath and saw something drip. The bottom of the transmission had a lot of oil on it, and then I also found there was some oil at the front of the bellhousing, just behind the block plate. It didn't seem like anything was running down from the fill plug on the transmission.
- Compression check: The last one I did, after retorquing the head bolts, gave me 162, 165, 170, 162, 165, 160. So it's not perfect, but it shouldn't be causing me issues from what I understand. This was done with the engine at operating temperature, all plugs out, throttle held wide open.
- Plugs: Replaced spark plugs, went back to an Autolite 46 (was using 45s). I've gapped them at both 0.038 and 0.034. Doesn't seem to make much difference.
- Other ignition components: New Motorcraft points, BWD Select cap and rotor. Plug wires and coil are still what the PO installed, but I do have a Flame-Thrower coil on its way.
- Timing: I've tried timing pretty much all over the place, and nothing helped the idle. I'm not sure exactly where I am now. I had verified my balancer didn't slip back in March, but then I checked again a few days ago and it seemed wrong. So I made a new mark and set it to 12 BTDC or so there, but that resulted in pinging while driving. So I've just backed it down from there. I guess I messed up when checking my balancer this time.
- Carb: I rebuilt it in March. Leaks a little at the main gasket, but I don't think that'd affect anything. I've also tried adjusting the idle mixture, but it doesn't seem to affect anything with the idle roughness either. Accelerator pump seems fine--nice jet of fuel when you move the throttle linkage. Just a regular Autolite 1100 still, manual choke, I think it's a '63 model but would need to double check.
- Vacuum leaks: I've sprayed carb cleaner around the carb mount and that whole area, but I never noticed a change.
- Mounts: Engine and transmission mounts are all fully torqued to spec and new.
- Oil pressure: Mechanical gauge never drops below about 40-45 psi while running. It also seems to have plenty up on the head when you pull the valve cover.
