Was the 36-1 trigger wheel off of a 3.8/4.2 v6?Got more parts to try. I ordered the 96 model 300 damper from Ford. It came with the 3 point reluctor. I removed it, to be replaced with a 36-1 ford edis. Damper fits as delivered. NO mods. The aforementioned ranger wp pulley lines up near perfect. It needs a 1/16" shim behind it. A standard clutch fan will clear damper. Now on to accessories.View attachment 15226View attachment 15227
That is mostly camera angle. Here is a straight edge showing alignment. Wp gasket thickness variations could slightly affect this too. I'll buy a shim kit at final assembly.NICE! Are the pullys aligned perfectly? Probably the pic angle, they look off. Serp belts are sensitive to alignment. Belt noise and longevity are at stake.
I haven't found a trigger wheel that bolts up. The 3 point wheel is 3 bolts, and a 3.8 36-1 is 4 bolt. The 2.3 and 5.0 wheels are pressed on damper. I removed a 5.0 wheel and made a spacer fit my 460 spacer. I'll probably trim 3 point wheel diameter off and graft on the 5.0 wheel.Was the 36-1 trigger wheel off of a 3.8/4.2 v6?
It bolts right up?
So a small update. I found this trigger wheel from 64bit_tuning_concepts. Still working in serpentine setup, but getting close.I haven't found a trigger wheel that bolts up. The 3 point wheel is 3 bolts, and a 3.8 36-1 is 4 bolt. The 2.3 and 5.0 wheels are pressed on damper. I removed a 5.0 wheel and made a spacer fit my 460 spacer. I'll probably trim 3 point wheel diameter off and graft on the 5.0 wheel.
not right now. I used that engine to mock up. It's now on the car. I'll try to get pics. Harder to see because I have electric fans too. The routing now goes from damper to Alt, then tensioner and over wp and back to damper. The belt wouldn't route behind tensioner pulley as shown. I'll reroute once I add compressorThanks for the post. Do you have an overall picture with everything installed?
