rustywagon
good it thank you
rustywagon":2raukm97 said:Hi guys, I am doing small progress, but moving forward.
I put in oil pan, pita..... not much room under car.
I installed timing chain, cover, pump, sway bar with new bushings.
I cleaned pistons, put all new freeze plugs on engine and head.
Question - do I put any stuff on head gasket? If yes, what's best?
First piston is up, distributor points towards cable to first cylinder, notch on crankshaft wheel is lined up with TDC on chain cover. Right?
