I have an aftermarket aluminum radiator with an electric pusher fan. The fan was installed WITHOUT any sort of temp switch/thermostat to switch it off / on when engine temps reach preset limits. Instead, its wired to run all the time (when ignition on).
I am going to order a relay and thermostat kit from the radiator company. But where would I install the thermostat? There should be a spot on the block somewhere or on the head, right? If so, where is it?
[When I say thermostat I am NOT referring to the thermostat inside the water system.]
I am running a 200cid motor.
Thanks!
Thanks!
