60sMustang
1966 Mustang coupe - 200 inline 6 C4 trans.
I've posted a couple other threads about some valve noise and cylinder head removal and got great feedback. Now that I have the engine torn down to the block basically I'm going ahead with a complete rebuild instead of just doing the top half(valve job, etc).
The head was well worn, which leads me to believe the bottom half is as well, no evidence of it being anything other than original. Replaced a couple valves and valve guides, rocker arm shaft was worn, valve seals leaking. I had hardened exh seats installed, 3 angle valve job, positive seals vs umbrella seals and upped the spring ratings to allow for a cam upgrade.
I'm looking at doing a .030 or .060 over bore with the comp cams 260H 110 degree LC. The head has been shaved down already to 48.5 cc chambers(already that way before I took it apart, they just took off the min to make it flat again). CR should be in the high 9's:1 when done, depending on the bore selection and gasket thickness.
Does anyone have experience with this specific cam in a 200? What's the idle like, Etc.
Recommendations on .030 over or .060 over on the bore and why?
