Gene Fiore
So, just like MPGMustang searching for more power...I went ahead and had annular boosters installed in my 500cfm Holley a few weeks back and headed out to the dyno today to see what's up. Last time I dynoed my car I had about 200 miles on my rebuild and was running the 350cfm Holley. Those numbers were 126hp at 4400 rpm and 158 ft lbs of torque at 2640 rpm. Too bad I never dynoed the car with the 500 Holley with the stock boosters...oh well. I know that the annular boosters provide a stronger signal and would require some jet changes. I currently have around 1500 miles on the motor. After a baseline run and two jet changes we ended up with 145 hp at 4800 rpm and 175 ft lbs of torque at 3700 rpm on the final pull. However, here in lies a problem. The annular boosters signal is so strong that we could not jet the car lean enough to achieve optimal air fuel ratio at WOT without causing other driveability problems. I currently have 64 jets in there. At idle its' around 12.7 to 13.2 but 11.8 running wide open...I know pig rich like wsa111 would say. I probably need the quickfuel technology metering block to be able to fine tune this. I'm guessing there's at least another 10hp I'm leaving on the table running so rich.
