Ok, I got my billet metering block installed Friday with the following setup:
.033 idle feed restrictions (this is what came installed with the block)
.055 pvcr with an 85 power valve (same pv as before)
69 main jets
emulsion bleeds as follows:
1 - top bleeds .028
2 - next down from top - blocked with blanks
3 - second from bottom - .028
4 - bottom bleeds - blocked with blanks
Throttle response driving on the street seems good...no flat spots...maybe could be a little crisper off idle but still nice.
Track results were not as good as I hoped, but I suspect it could need more jet. Car launched good and clean. Here are the results of 4 time runs:
1st pass - 9:19am - 60 ft 2.14, 1/8 et 9.7401, 1/4 et 15.2979, 1/4 mph 88.32 Carb open to outside air, no cold air kit
2nd pass - 9:52am - 60ft 2.14, 1/8 et 9.7353, 1/4 et 15.3125, 1/4 mph 87.94 Carb open to outside air, no cold air kit
3rd pass - 10:26am - 60ft 2.14, 1/8 et 9.7519, 1/4 et 15.3732, 1/4 mph 86.99 This run was made with cold air kit installed
4th pass - 11:45am - 60ft 2.16, 1/8 et 9.7752, 1/4 et 15.3681, 1/4 mph 87.82 Carb open to outside air, no cold air kit
My best 1/4 et to date in good air using the 4412 carb was a 15.26 at 88 some mph. I was hoping to see et's more in the range of 15.0 or thereabouts. The cold air kit seemed to hurt and judging by the drop in mph it would seem like it leaned it out too much...thus thinking it is now running a bit too lean? However, eliminations were about to start at this point so I did not want to attempt a jet change. I need to get back to the dyno to fine tune.
There was a small turnout for the 15 second class so it only took two rounds to take home the first place win...which I did.
