Heh Everyone, Looks like I need to step up my 250 rebuild, went out today and tried to start the old comet and it started and ran for about 2 minutes and slowly quit. I haven't started it for about a month, but it was running fine when I ran it then. I pulled the plugs and saw that they were all wet with gas, I had spark and fuel, so I decided to take a compression check which I have never done, #1 cylinder has only about 75#'s all the rest have around 140 to 160. This car ran great all summer long since the rebuild, and I had no problems with the motor, only small carb problems and timing issues which I had pretty much straightened out. Hopefully, it is just a burnt valve. I was not satisfied with the 3 angle job done, when the mechanic did the job, the head already had hardened seats installed and had the valves ground a couple of times already and there wasn't much of the hardened seats left in the head, He said he didn't like that, but they should be good enough. Any suggestions on what else it could be?
