144ci fuel pump torque specs
1962Falcon, my Manual says the following: "PRESS THE PUMP TIGHT AGAINST THE PAD, INSTALL THE RETAINING BOLTS AND ALTERNATELY TORQUE THEM TO 12 - 15 FT. LBS. ON 6 CYLINDER ENGINES AND 20 - 24 FT. LBS. ON THE V-8......." James
Interesting that Ford wanted more torque on bolts that are going into Aluminum vs. cast iron!
Maybe the bolts are different sizes? I don't know!
Will
