Hi Leroy!
When the vac lines are disconnected, the engine advances but sputters through low RPM until higer RPM when, presumably, the Centrifical advance kicks in.
When I put the manifold line on the advance side of the canister, not only does the car advance then (responding to the manifold vacuum) but on acceleration, the car does not sputter as much through low RPM.
A load o matic would not have the springs/weights inside correct?
My distributor has weights and springs, then the vac canister has TWO vanc lines on each side of the canister. Noramally, the carb vac goes to the advance and the manifold to the retard side.
For this experiment, I put a new distributor from MAC's/Cardone on the car. It came with the vac nipple on the retard side of the vac canister plugged with a plastic plug. So, rather than run the normal set up as the shop manual says, I was playing with the advance vacuum only swapping between the manifold vac and carb vac on the advance side of the can only.
I got a much better response from the car when the timing was set high and the manifold vac was on the advance side with not vacumm on the retard side.
I still have the SCV on the carb at this time. I am hoping when I plug the SCV or get the right '68 1100 to work with the dual vac distributor, the carb vac would be suffiicent to advance the distributor until the centrifical picks up. For some reason, I cannot get past some sputtering along the way. The only improvements I have seen is when the distributor gets more inital vac at advance I have the inital timing set almost off the timing marker at 16 degrees. Yet, I have no pinging, which tells me, and correct me if I am wrong, that the car wants more advance. Thus, the more advance I give it, the sputter duration gets less and less the farther I advance the timing.
However, the throttle response sometimes eliminates the sputter. In other words, I accelerate easy, the car doesn't sputter, but if I slam on the throlle the car sputters.
