deere114":3ddocgbr said:Well at the moment I'm running the stock cam. Trying to determine the best off the shelf option. I figured the overlap would build more power past 2500 rpm or so.
92f150i6":305zzucb said:Which lifters are recommended? Comp has 2 different models (Pro Magnum, High Energy), Howards has 2 different models, Crower, Rhoads, etc.. I'm just wanting a set that's going to last and work without modification, which I guess they all should work without modification. I'm getting ready to buy Comp Cam 942-12 Springs, 747-12 Retainers and 612-12 Locks. I can get them thru Tickwholesale.com $97.21 + Shipping. I just need to figure out what lifters and hopefully order them thru Tick as well.
92f150i6":36vsv6jj said:Shoot you are right, I selected the wrong part number. Stock locks should work with those retainers then.
Don't wonder too much!sthorvictor":3tp8mpmz said:looks good! good info i was also wondering about the Comp 4835 adjustable pushrod guideplates pmuller9..![]()
pmuller9":oy8tkzva said:Don't wonder too much!sthorvictor":oy8tkzva said:looks good! good info i was also wondering about the Comp 4835 adjustable pushrod guideplates pmuller9..![]()
The plates being shown are the Comp 4835 adjustable pushrod guideplates.
Read the beginning of the post that explains why the need to weld them together.
