Will be connecting new gas tank/sender in the next day or two and setting initial advance to 12 degrees. The wiring appears to be correct... working good on the dry run crank. So question about priming the carb. How much gas to pour in the carb, and is there an initial carb idle air setting to start with? Heres my setup:
65 mustang
1978 200ci with duraspark setup, mech. fuel pump, YF carb - SVA
Thanks!
65 mustang
Thanks!
