Tried to set my initial timing on a '65 200 today.
With the Loadomatic disconnected and the line plugged, the timing light told me that initial timing was advanced 30 degrees.
Couldn't be.
I pulled out the #1 plug, set the piston to TDC and the timing mark was on "Zero".
Checked the vacuum advance plate and it wasn't hung up but back where the springs return it.
If I try to retard the timing, I run out of space to turn the distributor and besides, the engine stalls.
This is an electronic Snap On advance timing light, with the advance set to Zero for initial timing.
Do you think the timing light is messed up, or am I missing something?
The reason I'm doing all this is with the vacuum advance hooked up it pings like crazy when accelerating and hot. Yes, the carb is correct with the tight Power Valve and it gives me 1 to 7 degrees of vacuum advance like it should.
Any thoughts?
Couldn't be.
Any thoughts?
I wasn't giving advice on building a space shuttle; the original poster had a discrepancy of almost 30º, by your math that's about two INCHES on the balancer; I was merely pointing out that a balancer which has slipped 30º is pretty easy to spot with the eyeball method.
