Finally have started putting things together, step 1 for me was to get the cam into place. Its been so long since I tore it down so I took a pic of the front where the spacer and the plate thing is and was wanting someone to either confirm or nnot if its all good and that I can go ahead and pop the dowel in all the way(any tricks you guys use?).
PICS!!!
http://s1224.photobucket.com/user/mercu ... 9.jpg.html -----> Bevel of cam spacer facing dowel?
http://s1224.photobucket.com/user/mercu ... 0.jpg.html
http://s1224.photobucket.com/user/mercu ... 1.jpg.html
http://s1224.photobucket.com/user/mercu ... 2.jpg.html
The cam can be spun by hand but I would like it to be easier, it was VERY easy to turn until all 4 bearing were in place but maybe Im just be paranoid. Used comp cams assembly lube on the lobes and dist. gear. wasnt sure about using it on bearings so I used my royal purple assembly lube.
Any thoughts/ideas I would love to hear them
PICS!!!
