200 engine with aluminum oil pump
Crosley
this 200 cid engine has an aluminum body oil pump.
I inspected the pump and the insides look near new. The end cover where the pick up tube bolts onto the pump is cast iron
Is it a good idea to run an aluminum oil pump on this engine?
Some drag racing will happen with this engine.
8)
When using aluminum parts exposed to anti-freeze, use the purple type. The green type ate my Edlebrock manifold after the car sat for some time after a wreck.
I don't see why not. That's all I've ever used. I'm not sure I've seen an SB6 OEM Ford oil pump that was not aluminum. I think the replacement stuff is cast iron.
If your oil pump is exposed to Anti-freeze, you've got problems.
GMB make and sell the alloy water pump. I think even Summit may be able to supply them at present on an order-in basis.
As to the oil pump - years back, you used to just be able to buy a rotor kit and resurface the cover's inside. That would let you use an OEM cast alloy unit.
