my 200 in my 67' stang is running rough.So far I am not driving the car but I am trying to get it ready so when the rust repair is done I can pull out of the garage and not look back..
So, the previous owner was a moron and could have done almost anything to this car. The condensor was missing in the distributor for some reason which took me a day of starting fluid, new plugs, new cap and rotor- before I noticed it was not there.
Also, the air filter was off of a 2bbl carb and was way bigger than the 1bbl opening, allowing it to suck up dirt- it was chrome and looked neat though. I do not believe it was driven like this though.
The carb (and the rubber hoses) were all spray painted chrome. (probably wont affect anything, but what an idiot)
Now that you have the story, I have it running but it bucks and sputters at idle and wants to die if I rev it up too much. I adjusted the timing and for some reason it wants to run well at about 20 degrees. I beleive it is supposed to be like 12-(some idiot spray painted over the engine decal that would've told me)
Once the engine warms up it starts to sputter again and no amount of timing movement will stop it. This leads me to believe thatthe carb is out of adjustment too. All I have touched on the carb is the idle screw so far.
Anyone have a suggestion what I should do next? I dont want to get too many variables going at once.
