I just bought a 76,000 mile 1981 Mustang for a couple hundred. It has the 200 in it. I heard it spark knocking on the highway, so I decided to check the timing. I pulled the advance off and plugged it. Then put the timing light on the plug closest to the front of the car. The timing tab is on the driver's side, but under the timing light, I can't see the timing mark on the crank at ALL.
After some investigation, I found I could see the mark about 180 degrees around, on the passenger side of the engine........ does anyone have any ideas what could be wrong? The car runs and drives excellent.
