I'm looking into making my purchases for new pistons/rings, head gasket, and cam/crank bearings this week, so i'm trying to figure out what I have.
I haven't had an opportunity to check my cam yet, but when i measured my block and crank, this is what i got:
Bore - ~3.74". book says 3.680, so that looks like 60 over to me.
Deck Height - ~ 7.8". I measured from the bearing cap seat at the front of the block to the top of the block. I can't find a spec for that in my Chilton manual, am i measuring it correctly, and does that sound right? I need to know these things (as well as my chamber size) so i can play with piston/gasket combinations to get a CR and figure out what parts to get.
Stroke - 3.130" (i assume it'll be stock from the book)
Measuring my Crank, I get
Main journal - ~2.238". looks to be 10 under so i'll need oversize bearings.
connecting rod journals - ~ 2.115" also looks 10 under as well.
Does anyone have a suggestion on how to CC a chamber? i assume i need to use a syringe to fill the chamber, tracking how much i drop in, or is there another (better) way?
I've read that overboring a cylinder raises the compression ratio, so I'll probably have to get dished pistons again, but i'll need to run the simulator to tell for sure.
I'm a little confused by the calculator here:
http://falconperformance.sundog.net/compcalculator.asp
But i have the book on order. When i get it, is it going to explain the process a bit, or am i just missing some core knowlege?
-joe
-joe
