223 in 63 Galaxie project and question
63Boxtop
My Galaxie is equipped with the two speed Fordomatic and in my mind it seems difficult to go with any of the performance intakes or multi carb setups due to the transmission kickdown linkage. Any insight into this?FF2D75E1-2637-410F-91D3-CC07DC1CB028.jpeg
63Boxtop
My 63 223 has the silent lash rocker system. One of the eccentrics had this bad wear spot....all others fine. I did replace it with a NOS one I had. FD82DDFC-8302-4263-A489-0C246E435C68.jpeg
Top Poster
Staff member
Supporter 2021
Supporter 2019
REDLINE 10K
The aftermarket intakes usally will have the boss cast on the intake just like on a stock 223 intake so that your throttle and kick down linkage should bolt right on. On your rocker wear did you make sure the rocker arm shaft is clean inside so that its oiling properly on all the rockers? Best of luck.
63Boxtop
I actually thought about that yesterday when I was doing an oil change. I imagine it has to come off and be dismantled. It does not look overly complicated. I will have to dig into the shop manual. One of my concerns is that oil supply line and the little o ring at the bottom. Does the o ring come out with the tube? Some information sources I have researched in the past seemed concerned about messing with this as it is no longer available at least according to them. I have left it alone till now but eventually something has to be done. I don’t think I have had someone with your level of experience with the 223 to give guidance. The oiling at the top end has been something on my mind....just not sure how much is supposed to be up there.
62bigwindow
Active member
Here is a pic of a Fenton manifold. It has the same holes for the linkage as your stock manifold.
63Boxtop
I noticed in your other intake photos that they also had the boss for the linkage. On the stock manifold the linkage is positioned where the rear carb would be on a dual intake. The linkage position on the dual intake would put it in the middle with some type of extension or other modification to get around the rear carb on the inside and link up with the kickdown rod. I noticed on the Offy website they mention that with their dual intake there is not enough clearance with the hood in passenger cars. How about the other vintage intakes. Is there one that has clearance?
Top Poster
Staff member
Supporter 2021
Supporter 2019
REDLINE 10K
It dosnt need to have very much oil to the top end but it can't be dry, try running the engine at idle with the valve cover off and see if all the rockers are oiling.
I had a realy nice Clifford Ram Flow single 4V intake with a Holley, in my OPIN its one of the very best 223 intakes ever made and I think it was the only single 4V made. If you could find one of those it could work good on your 1963 and I think it would also be a lower in over all height.
63Boxtop
I did run it with the valve cover off with the oil return line popped off and after a few minutes I got oil coming out of the return hole. I will do a more careful check of each rocker in the next day or so. I also have no concerns about taking the whole assembly apart for cleaning. I just have to make sure I can source a few of the parts I would need like the plugs for the ends of the rocker tube and that pesky o ring on the oil supply tube.
I did look at that Clifford intake and it looks like a good option. The carb stays in the middle so it would be possible to weld on a tab for the kickdown linkage near to it's original location. Then I need to find out if their headers will clear my power steering pump under the generator. It's pretty crowded down there.
63Boxtop
Couple of other things I have done recently. Had my copper radiator re-cored and removed and reconditioned the fuel tank. The fuel tank project was driven by the fact that I twisted the drain plug fitting out and since it had a flange on the inside it fell into the tank. I fished it out thru the sender hole. I cleaned the tank out with a combination of E 85, a motorcycle chain and then phosphoric acid. After I got the plug loose from the drain plug fitting I used a stiff wire with a loop on the end to fish the fitting back into the tank and using the wire held it in place while I soldered it back on. Cleaned up and repainted the tank and straps. The tank was solid to begin with so I thought it worth the effort to save it. radiator.jpggas tank.jpg
Top Poster
Staff member
Supporter 2021
Supporter 2019
REDLINE 10K
New rocker shafts and end plugs should be easy to get new there also used to be new rocker arm bushings though I haven't looked for them in awhile. There is also a rebuilding service for the rocker assemblies
62bigwindow
Active member
This is the height with a Holley 1904. Not sure how much there is in a car but probably add at least 3-4" for a breather.
63Boxtop
I stood a tape measure on end on the intake with several inches extended and closed the hood. In the position of where the forward carb would be I have seven inches. More in the rear of course. I have the autolight 1100 carb and the overall height from the manifold to the top of the stud is seven inches. The stock breather doesn’t add any height.
