Daves55Courier
I had planned to replace the Load-O-Matic distributor with a Ford 240 cu in distributor with mechanical advance, but Cardone does not have any rebuilt cores so I will need to wait until they are offered. Unfortunately that means I am stuck with the original Load-O-Matic.
Fortunately, my fuel bypass system worked and now the engine runs without carb flooding out, however, when I try to rev the engine RPMs, it seems to loose vacuum to the vac diaphragm at the distributor. Engine looses power. If you put it in gear and try to rev engine, it will die, but it will re-start and idle with no problem.
I checked manifold vacuum. It is steady at 18.5 at idle speed.
I replaced vac can with a new one. Still looses vacuum.
Checked engine timing. Its right on the money at 6 degrees BTDC with dizzy vac disconnected and plugged. Checked timing again with vac tubing re-installed at dizzy can. It changes the timing about 1 or 2 degrees, which I think is about right.
Intake manifold does not appear to be cracked anywhere (and if it was it wouldn't hold vacuum at 18 on engine idle).
I put on a different Holley 1904. No change. It act exactly the same as with the other carb.
It is beginning to sound like the distributor advance cams are way too far out, but I never changed them and the engine never acted this way before. Any suggestions???
congrats on getting it dialed in
