2300 carb
Will the 2300 series carb fit the clifford performance adaptor im hoping so if not what can I do to make it fit. I already have a 38/38 progressive carb on but im getting the 2300 custom built for turbo. So alittle info is needed.
No the 2300 will not fit on the 38/38 Clifford adapter, but Clifford does make a plate for the 2300 to bolt on top of the 38/38 adapter. This is the set up I'm using. Now, you're probably wondering about hood clearance. I am using a drop base 14" K&N filter with no problems.
.................Cheers, Alex
