TCSTEVE
OK finance is organised and so is the engine builder, the engine comes out in 2 weekends.
If you guys remember i have a TC Cortina and i want to run around 250 HP N/A manual and keep the Borgy diff, would like to keep it at 2.79 for crusing but a 13 sec pass would be nice. It's still going to be a daily driver and i don't wanna go to crazy on wheels,drivetrain etc
Is there a lsd centre for my Borgy that runs 2.7 or 2.9?
I've got this so far..
want to run a 4 barrel and will probally have the 2 barrel torker manifold cut and welded to suit, hey it already fits.
Oversized valves (probally 289)
smothed inlets and manifold wondering wether it worth it?
Enlarged exhaust ports and matched to oversized tuned length pacemakers,cone welded etc 2 1/4 exhaust allready on there
Aftermarket rocker gear maybe stud guides etc - still undiceded on this
Double valve springs
shot peened standard pushrods
solid lifters or would anti pumps be better?
ACLpistons/200 rods kit can someone give me an idea on cost for the kit?
set of timing gears and chain
aftermarket bearings
ARP rod bolts and head bolts
Full engine ballance including lightened flywheel
Electronic dizzy possible XE/XF plus coil
High volume oil pump/ baffled sump
Still not sure on the holley really like the large primaries smaller seconary idea and not yet decided on the cam????
I know most of this sounds like overkill and big $$$ so any help and advice on whats not needed and any ideas on the holley and cam would be greatly appriciated!!
Long live the i6
Cheers Steve
Long live the i6
Cheers Steve
