250 bore
The reason I'm asking about the cylinder bore diameter is, I found a set of pistons that will work with my build that are 3.80 dia. aussi7mains helped me eliminate those pistons. I also found another set that are 3.691 dia that will fit the build.
My build will be those pistons, 300 rods, 3.91 stroke. The head is an E0 head with 3 740 webers. The cam will be a .515 lift 280 duration 110 LSA. I am getting ready to retire and am going to build this engine. I have 4 more heads and plan to build a 2 carburetor head, and independent runner intake for these 3 carburetors. My goal is 250 to 300 horsepower.....
Compression height
The distance from the center of the wrist pin to the top of the piston, technically it might be to the top of the compression ring. It will change how far up your piston will be at tdc
an alternate 250 Piston in my '61 is AMC/IHC 4.2/258 (TRW/SealedPower # 470NP std) Pistons require an .070 over bore to 3.75" .
The trick pony' of these pistons is the CH raises piston height .133 about where stock pistons are down from deck similar amount -
AND specs list the pin diameter of the ford at .9122 and the AMC's at .9310 which can easily be accommodated.
from the wayback machine:
"The AMC Pistons depression is much bigger than a 200/250 piston , 2 to 3 times the volume. CR lessened significantly and still maintain zero or negative deck height with the .133 additional compression distance"
hav e fun
250/258 will launch at 5500 and still has drivable low RPM grunt ...
That piston is only .011'' larger than stock, I do not see it cleaning up with so little to work with. I had a very hard time finding one that would clean up at .020'' and that block had air bubbles in the bore casting. Keep in mine that #1 bore wears more than the rest.
The Ford 300 rods use either a .912” pin or a .975” pin. The pistons you are looking at have a different pin diameter.
Also the 1.24” CH has the pistons about .060” down in the bore at TDC.
