six shooter maverick
Active member
Ok so here it goes, I'm puting a 250 in my 69.5 maverick. its a 78 engine out of a granada so farits been rebuilt but its lack luster compared to my stock 73 engine. Engine specks as i know
78 block 30 over smog dish pistons
Stock cam
78 head rebuilt with 3 angle valves
parts i plan to put on
Clay 264 264 110 cam
Dual out header
Adjustable rockerarms
Duraspark ii
2 into 1 carb adaptor w/ autolight 2100 1.08
Is this a good start? Should i put a higher stall converter if so what rpm v8 spec should it be? I eventually want a head with split manifold but hear theres clearance issues in the mavericks with the ci intake. Any help is great.
I do wanna build a block with new rods and pistons eventually so that advise is great to
Stock cam
Dual out header
Duraspark ii
