Help please, this is holding up the completion of install/startup of 250 with 157 tooth flywheel , C5DA Bellhousing & standard (3spd) tranny:
The 1969 Mustang 250/std - 9 TOOTH - gear OEM starter application interferes with the headers. Common wisdom says the later VeeAte 82 - 94 5.0 starter will work fine. (also has 157 tooth flywheel)
> The OEM 9 TOOTH is centered in the bolts/flange bellhouse opening.
> The '91 5.0 starter I got has - 10 TEETH - but armature is offset from the bellhouse flange mount opening and bolts center and has "offset / angled gear teeth" .
Anyone know if this is going to work? - or will it shred the ring gear?.
This has been a frustrating issue - Anyone using a 250 with standard tranny I'd sure appreciate letting me know what starter you're using.
Thanks,
Powerband
91 5.0 starter:
OEM application:
Thanks,
Powerband
91 5.0 starter:
OEM application:
