If you have a 144, it must be an "Early Roundbody". Replacing it with a 250 will make it a different car. Along with the 250 , it probably will use most of the 250's drivetrain to make a reasonable swap. Plenty of info if you search on 250 . Here's one on early roundbody 250 's: http://fordsix.com/forum/viewtopic.php? ... highlight=
The "bolt on" swap for your 144 is a 200. Most years will bolt right up to existing drivetrain.
Lots of modifications to put that into a 61. I've got a 250 sitting in the garage that will never get under my hood with my limited skills at fabrication & limited funds.
That's why you're better off with a 200. It will bolt up to your transmission and fit under the hood. The 250 is almost 2 inches taller and an inch wider. The great thing about the 250 not to mention 25% more cubes is that you have a good selection of transmissions because like wallaka mentioned it has the 289/5.0 bellhousing pattern.
Where in Calistoga do you hang out? It's been ages, but I used to work at the Calistoga Inn for years.
Unfortunately, parts stores will have very few of the parts needed for early roundbody conversions. . Forum contacts and sales, car show swaps and Evil-Bay are options. Work up a clear list of what you will need, there are always options..
