Well, no. I have to think what happened since then. I replaced the dizzy with 1968 nonLoad-a-matic and things got better AND worse.
It got better in the fact that it actually started advancing the timing. It got worse in that I just could not get it timed correctly. I also had all sorts of issues with the carb (I think that is in a different thread). When I finally got it to a point where I could sort of drive it, it would either ping like mad or run like crap and stall if I back off the advance.
Since then, it has sat in my garage where I simply scowl at it whenever I walk by. Could be worse, my wife keeps dropping hints that I should sell it since I dropped $4000 dollars into it last year and still can't drive it.
Also, it is the middle of Winter here and my garage is not heated. Seeing as the temp has barely been above freezeing a couple of times in the last month, I just can't work on it till spring.
I have got offers from two local FordSix'ers (John G and Mercman63) in the area to help, but I will have to get it at least drivable to get it to them for help. I am starting to think it is the carb and I should just replace it. It was new 12 yrs ago, but it sat for 10 years and now is really problematic. The main thing being I can barely get it to run without losening a jet holder screw (which should be tight) and actually causing a vacuum leak in the carb. Unfortunately, I just dont have the skills to rebuild it and can't afford a new one at the moment.
Ugh.
