2bbl or 4bbl carb on 250 2v engine.
Stumps
I've narrowed down the carb selection to two carburetors for my 250 2V build in my 74 XB Futura and I'd like some opinions.
I'm thinking of either going for an Autolite 2100 with 1.23 venturi (356cfm) on the factory 2 Manifold
Or
A 4100 with 1.08 (480 cfm) venturi on an Aussiespeed manifold.
Obviously the 4100 is a fair bit more expensive as I have to purchase both the manifold and carb (unless I use a 2bbl to 4bbl adapter, not sure how well that would work) but it would yield more overall power and I suspect better economy at light throttle settings given how much smaller the primaries are.
The 2100 would be easier to mount as I already have all the brackets and manifold to suit and cheaper as I only have to buy the carb (I have a rebuilt 1.14 venturi already).
I am chasing 220-250 bhp from the engine.
Which is a 30 thou over 250 with a 2v head with oversized valves fitted, a 214@50 thou speco cam (may change to a 224@50 thou crow cam) comp ratio is 9.5:1. The ignition will be a rebuilt points dizzy with a MSD ultra 6AL plus CDi module. The exhaust is pacemaker header into a dual 2.25inch system.
The trans is a WC T5 and the diff is a 3.27:1 lsd.
Is 220-250bhp doable or am I dreaming?
What would give better results the 2 barrel or 4 barrel?
The 4 barrel is much bigger, as the CFM formula used for 4V carbs is not the same as 1V and 2V. CFM can not be directly compared between 1/2 vs 4.
Using the 1/2 barrel measuring standard , a 4 barrel with 480cfm would be rated @ 677cfm. Reversing this, using the 4 barrel rating standard method, the 1.21 carb @ 353cfm would be rated at 250cfm.
677 over 353= 1.92. The 4100 is 92% larger than the 1.21 carb.
353 cfm will not starve for air on a 250" engine @ 80% VE until 6175 RPM. 677 cfm will not be fully used until 11,850 rpm.
Yeah I get that 2 and 4 barrels are measured differently, which is what makes things confusing.
I know 4bbl's are measured at 1.5 inches and the 2bbl is at 3 inches but how do you determine what is the correct measurement for the engine?
289 V8's are often factory fitted with 4100's or bigger and they work very well, a 250 is only 39 cubes smaller so carb size wouldn't be that much different using the usual formula's
My understand of Vac secondary carbs is the engine will only open the secondaries as far as the available vacuum will allow so lets say on an engine that can only flow 350 cfm then using the 4100 as the example the front venturi are 240ish cfm which would provide better down low response compared to the 350cfm 2 barrel. but when the throttle is opened right up then the secondaries will only open 110 cfm or so...that is my understanding of how they work and I have seen this in practice with our 2v 302 and 351's Clevo V8's here in Australia in Falcons getting better cruise economy and low down response when changing from the factory 2 barrels to a 4 barrel which has smaller primaries such as a 600cfm Holley or something similar.
I could be way off here and maybe 6 cylinders are measured differently.
very happy to be corrected on this.
No correction, you've got the picture. There's no "correct measurement" for a specific engine. Manifold vacuum will increase from zero when (if) a carburetor begins to be a restriction to the incoming flow demand of the engine. So if an engine maxed out the 2150 and the intake read 1.5" of vacuum, that would be drawing 250cfm. (from the calculations in post #2). If the engine keeps increasing rpm and reached 3" of vacuum the same 2150 carb would be flowing 353cfm. Carbs don't suddenly shut off, the power continues to increase, but to a lesser degree with a smaller carb.
A possibly simpler way to get a mental baseline for deciding a carb is, how many cfm does the engine actually consume? Assuming 80% volumetric efficiency a 250 cu in 4 cycle engine consumes this:
1500 rpm: 87cfm
2000rpm: 116cfm
2500rpm: 145cfm
3000rpm: 173cfm
3500rpm: 202cfm
4000rpm: 231cfm
4500rpm: 260cfm
5000rpm: 289cfm
5500rpm: 318cfm
There is an additional factor I call the "gulp factor". Since piston engines are not a smooth inhaling rotary pump, the intake cycle is a relatively quick burst of inhaling, carbs that are larger than the engine's net air consumption make more power (usually) because there's extra flow capacity for those spikes of intake cycling. Intake manifold design plays a big part in the "gulp efficiency" as well. A larger plenum intake can use a smaller carburetor, since more air for the gulp is already present in the intake.
You pointed out a 289 having a 4100- true. But most factory carburetors had a cfm rating very nearly equal to the cubic inch of the engine. Smaller carbs get a better vacuum signal internally, so they have better cold-start, quick, sharp throttle response, and good economy. 280cfm 2V carbs made 310lbs of torque and 210HP on 307" V8's, for example. The 353cfm 2150 carb came factory on thousands of 351 and 400 cubic inch V8's.
None of this is advice, there's pros and cons to both carbs you're considering. Either one can be tuned to run very well and strong on your 250.
Or
Small 4 barrel around 500cfm will work on the Aussiespeed manifold, stick with the 214 cam for everyday driving, the 224 will be a bit rough. Run a Bosch Australian made ignition with its matching coil and 12v supply via a relay, MSD is expensive and unnecessary. Your exhaust sound perfect, Ive found a single 2.5 with trubo muffler to be best, but there isnt much difference, twin will be a bit noisier, and cost more. A divider welded into the middle exhaust port fit the headers better, but isnt essential. 9.5cr is just fine, filling the cylinders is more important than high compression. 220-250 is a bit high with this combo, 200 more real, but thats still comparable to a good 302. Do run an electric fan and ideally a electric water pump to reduce parasitic losses. Cold air works as a cheap power help.
One important point I would like to share is the importance parts availability. In the US, many enjoy using the Autolite 2100 & Motorcraft 2150 carbs. But good used ones are becoming hard to find. And, parts are starting to become difficult to get. We all know that China makes clone carburetors but my understanding is that it’s a crap shoot getting one that works properly. Then there are my feelings towards purchasing anything from a country that we don’t have a good relationship with.
If you already have a good Autolite carb that will work properly, give it a try. What do you have to loose? If it’s worn out, then it’s time to possibly consider getting another carburetor.
I personally would purchase a new carburetor. The reason why, many carburetors from the late 1960’s through 1970’s are worn out and chances are, someone else is trying to get rid of their headaches.
I’m in favor of Holley and Quick Fuel carburetors. Over the past three years I’ve learned to tune them, and the Holley 390 4 barrel is perfect for a near stock 300.
I’ve found that once Holley and Quick Fuel carburetors are understood, tuning them is a piece of cake. And overall, they are very reliable.
Are they cheap? No. But the old saying goes “you get what you pay for” is true in some cases.
A Holley 390 vacuum secondary 4 barrel would be a good fit since the primary are smaller than many 2 barrel carbs. The secondary will open as needed on a properly tuned carb.
If a Holley 390 carb was not available, I would most likely use a Holley 350, 2300 carb instead. It’s a very easy carb to tune.
Oh, last thing:
In order to tune any carb, an AFR meter and vacuum gauge is recommended.
Are you going to lock out the distributors mechanical advance and use the MSD Ulta 6AL plus to program the ignition timing curve?
Oh, last thing:
My current 1.14 2100 was rebuilt from scratch about 10 years ago to suit a big cammed crossflow 250 that I had in a cortina but the carb got shelved before it ever had any fuel go thru it as the car was sold before the carb arrived back from the reconditioner.
I'd image it'd bolt straight on and run with minimal adjusts, so it'll go on first during the run in period of the rebuilt engine.
If it was a 1.23 sized one I'd just call it a day and use it out right and not mess with a 4 barrel, but as it isnt I'm left wondering what more can be gotten from the 250.
Maybe overkill but- whenever I first fuel a carb that's been dry for a long period, I ease the first fuel to it. Fill the bowl via the vent, a hand squeeze bulb, or intermittent application of mechanical/electric pump- to fill the bowl gradually. Sometimes suddenly shocking a dry carb with full pressure, it will blow past the needle/seat before it has time to get moist and function.
A quick fuel 450cfm carb is next on my list of carbs, a new one is certainly a lot cheaper than a rebuilt 4100.
How do the quick fuel carbs compare to a proper holley? do they fix the usual issues with holley's like leaky fuel bowls and generally being unpleasant to keep in tune?
I've run a few holley's in the past and found them to be very meh....I've had better luck with the 4 barrel 4160's than the 2 barrel 7448's which just tended to make things a bit thirster for little performance gain.
a 38mm Weber DGES might be a good option as I have run the ADM34 weber on crossflow sixes before many times and they are a very reliable carb, just a little small for top end power.
Shame there isn't a progressive version of the 38mm as it would be a close to perfect option for this build.
I normally give a carb that been sitting for awhile good soak in clean fuel to allow the gaskets and seals to moisten up first before fitting the carb and then trickle a little bit of fuel down the bowl vent tube to fill the float bowl a little so it isnt dry on the first start, a good wipe down with a clean lint free cloth, prevents it from bursting in to flames if there is a misfire 🤣
1000001298.jpg390 works ok on a crossflow, even kept the heated plenum, and the electric choke is a bonus..
There's a couple different attempts there but you get the idea. Just got it under an xf bonnet with a drop base air filter.
What did you end up settling down for? I'm having similar thoughts.
I have an Argentinean 221ci L6 Falcon with stock heads and 1 barrel carb but I'm looking to upgrade to a SP style head (with better flow, bigger valves, separate intake not casted into it, etc) and was doubting with going the common way here with a (36/36, 38/38 and even 44/44) 2bbl or doing a 4bbl 390cfm or 450 cfm with vacuum secondaries and electric choke
