I have a '65 Mustang coupe, 200 CID, 3 speed tranny. I purchased a remanuf Autolite 2100 carb from Advance Auto Parts on top of an adapter from Summit Racing. Bought a new throttle cable and used brackets which work fine. Even kept the same pedal and rod under the dash, with extensive modifications. But, I can't seem to get the carb tuned. No RPM guage, so not sure if idle is set right. Of the 2 screws on the bottom in front, the left screw has to be screwed out about 3 turns to get the car to idle at all. The right screw makes NO difference at all, screwed all the way in, or all the way out. Runs OK at idle - little miss. Runs terrible above idle. Vacuum advance was not working, but that is now changed. The car actually ran OK before the Vacuum advance was changed, but still wanted to die on takeoff. Timing is another issue. The mark on the harmonic balancer is off from timing marks, like 1/6 the circumference of the pulley - 1 cylinder. I put everything together right, all marks alligned. Ran good with the old 1 barrel on it for 3 months, with NO vacuum advance. Last day of driving with the 1 bbl, the car stalled. Had to hold to the floor to restart, and high RPM's to even move without the car dying. I baby'd her home. When it died, gas came back up through the carb. I wanted to upgrade the carb anyway. But, now I need help/advice to get my 65 moving again.
