300 carb on 250 head with bolt on pedal and cable... all fron the junk yard
so I have 2 carter YFA 220cfm one does have smog everything
the other smog nothing
(Thanks 82F100!)
to get the carter to fit on the head I found a 250 carb spacer that had EGR crap on it, I've grinded it off, and will fill it with the JB-weld
the pedal and throttl cable I scored off a 90's grand marqui, has the snap on ball connection. not too sure about the pedal but I'll see once I'm into it.
found a f150 with a 300, snagged braket for the cable because it fitted the cable and I'll be able to run a bolt to lock it on.
the end goal would have me be able to bolt on and off either the autolite 1100 or the carter YFA, sadly when I would like too, I'll have change over my pedal and linkage every time, hopefully I'll think of a way...
thanks guys because of you there are plenty of searchable topic's here that have helped me out for cable gas pedal conversion, I just thought I' might share what I've found so far that might help others.
BTW the cable and pedal and cable braket was $13 today, half off thursdays
I'll hopefully post some picks when it's done.
