'66 200 Mustang Power Brake Conversion
Greg Gaitens
Active member
I have converted my front brakes to the Granada disk brake assy. I have a dual resevour master cylinder with proportioning valve. I have removed the orginal 6 cyl. rear end and replacxed it with one from a V8 Mustang.
I would like to convert to power brakes. Stainless Steel Brakes tell's me their kit won't work with '66 cars with manual transmissions as their parts interfere with the clutch linkage. I can not use a clutch cable as I have converted to a T5 trans. and I do not believe there is a clutch cable kit that will work with my bell housing and clutch fork.
Is there stock power brake stuff that I can purchase that will work? Is there other aftermarket conversions out their other than SSB?
