Howdy Gwk:
And welcome to The Forum! Yes, it is that good.
1st off your '66 170 Autoltie 1100 is rated @ 150 cfm.
THe differences in Autolite 1100s from 1967 and earlier to 1968 & '69 are the loss of a Spark Control Valve (SCV) that links the carb vacuum signal to the Load-O-Matic (LoM) distributor. '68 and later engines have a distributor that utilizes both vacuum and centrifugal advance. The vacuum signal is a ported vacuum source from the carb. The other difference is that all 1100s got a cfm of 150. For the 200 engine that is a downsize from 185 cfm previously. For 170 engines this is not an issue because that has always been the 170 size.
Calif Emissions engines got this carb/distributor change in the '66 & '67 models.
So for you, the difference is the SCV on '67 and earlier 1100s. No SCV on '68 & '69. There is an informative stickie at the top of this topic on SCV and how it works. Basically it gives a load sensitive advance signal to the LoM distributor.
Again welcome. Enjoy.
