ManikMaster
Active member
Hey all I am looking to build up my 67 200...
Currently i have A T5, electronic conversion kit with standard distrib, 289 radiator, grenada brakes, stock rear, stock everything else...
I want to get more top end and mid range power/speed. I am running an Autolite 1100 and think that I might want to go to multi port fuel injection vs bigger or more carbs...
Pro's Con's?
I was thinking maybe get another intake to try this out on rather than killing mine...
Also, I want to build my matching numbers block and head for more power/flow. I am currently thinking Port and Polish head, Roller rockers, stiffer springs, new distrib, new oil pump, new fuel pump, header, new bearings, cam, blueprint&balance block, high compression rings and 3 angle valve seating...Basic TRIPOWER...
I know there are others out here who have done similar builds and would like any and all input as well as pros and cons on these subjects...other suggestions, brands, prices and ideas are also appreciated!!!
Finally, I would like to be open to the possibility of turbo in the future andw as wondering if the stock pistons would be applicable or if I should spring for new ones...
Ps i have good technical skill and mechanical ability, and if anyone wants to see pics just let me know!!
Thanks ford six gods!!!
Manik
Pro's Con's?
Manik
