beechgrove1+
Recently purchased a 67 stang coupe with a 200 L6 engine and c4. Appeared to be the old ford re-man green long block. No carb or fuel pump when I got it, I disassembled engine with machine shop doing all the head work. Installed an overhaul kit from napa, 30 over rings, all bearings, new cam kit with lifters, new hei distributor. A re-man Autolite 110 one barrel. After startup has #1 and #2 cylinders dead. No amount of adjustment on carb or timing works. Plugs are black and sooted on all but 1 and 2. Plugs are firing outside engine. Compression 180 on all cylinders with no leak down. Tried new plugs, no availe. Looking for suggestions please.
edited
Sorry but there is just No way period! The carb is sitting on a intake log that's connected to all Six of the engines cylinders so if it was the carb not supplying the fuel then none of the other cylinders would fire either. There are only a few items that can cause these simtoms too happen.
