Hey Guys,
Hoping this is an easy one... I am looking for advice/tips on how to have my throttle return spring set up. I believe I am getting a vibration when my spring rubs against the air filter housing and just in general it does not look secure and clean to me.
I know the older models had a spring connect to the exhaust manifold but that does not seem to be an option for 68, I think. Any suggestions are welcome.
Here is an old picture but it shows the current placement of the spring and how it rubs the air filter housing flange.
		 X2 I am with B Ron Co in the opinion that Its not a stock OEM Ford part or return spring. But even so you could just drill a new hole in that home made bracket so the throdle return spring moves over closer towards the engine and is also pulling straighter. Looks like moving it about 1 1/4 to 2 inch towards the engine block should  help it clear the air cleaner tube. After you get it to clear you could then cut off all the excess lenght of that bracket round the corners off so it looks a little better too. Good luck
