So where the problem is the lack of a factory tank option under the bed for my truck. The 73-77.5 4wd F250s (colloquially know as highboys) have a completely different frame that is narrower from the cab rearward compared to the other trucks in the lineup, so Ford stuck a gas tank in the cab and called it a day, and there's little aftermarket support.
I didn't want to mess with in line EFI pumps since in tank is better, but there isn't a good way to modify the in cab tank for an in take pump, plus I didn't want the noise of a pump inside the truck.
So to get one under the bed, I have a few options
1. Buy aftermarket tank designed to fit from Aerotank or FFG, the only companies making something that works with the narrow frame
2. Modify tank from another vehicle to fit - bronco 2 tanks have been made to work in the past
3. Generic fuel cell in the bed, but that takes away bed space, and cells are usually small.
4. I design one and have it built
