After you lap the valves in. Take the intakes to a machine shop & have them do a 30 degree back-cut close the the outer lapin line.Maholmes76":2aqfpdcc said:Was lapping the valves today and noticed small Annular groves as I did them. I am using the lapping hand tool. And permatex valve grinding compound. Is this going to be ok. Not sure this is the first time I have lapped valves
A 30 Degrees back-cut will gain you 10 HP.Maholmes76":2mpk7npa said:Chad
Sorry for the lack of response. Not real good at this forum stuff. I have been taking your advise. And getting my ducks in a row. Can’t find a way to respond to just you if you even can. Still learning.
Wsa111
Thanks for the advise. So to be clear you are telling me to have the intake valves cut back correct?
Now that I am getting my stuff together I will post all my info on the car cam ect and we can figure out the carb and Distributor
Maholmes76":2khlzqxl said:Ok it’s the 250. I ordered a comp cam for the 240-300 and thought I had messed up but come to find out the cam I ordered will fit all 10 inch deck height straight sixes.
the marks are to B ignored.Maholmes76":3eqqgt19 said:...that way the timing marks will not be advanced. Thanks again!
gb500":5rdz8g5m said:These 1.88" honda rods - what model / engine are they from? And what's the c-c distance?.
Tried a search here. - but 1.88" is too small for the search function
