(Wifes' name for car: 1979 Fairmont Ghia Coupe 200-6, C-4, P/S, PDB, A/T, A/C. 62k original)
Bought this car about a year and a half ago from family of original owner. Very nice condition.
Have been reading through the site here, bookmarking, and making a few plans.
Commenced de-smog ops a few days ago; Thermactor and other controls have fallen off. EGR, PCV, thermostatic air control remain. (EGR now run off of Holley 1946 stock ported vent, but through a two-port PVS switch.) Cat convertor soon to fall off.
Cranking compression shows 180-190 in all cylinders.
Dura-Spark II tests out correctly.
Now, to tuning. Car was passing smog check with aplomb, but wanted to remove all "unnecessary" equipment for reliability/simplicity plus trying for a little more pep and fuel economy.
Timing was 6-degrees BTDC (w/o vac advance hooked up); now at 14-degrees. Missing acceleration now found. Vac advance is hooked up to manifold vacuum, and carb fuel/air adjusted to best reading (20 in/hg)
at 500 rpm in Drive. (Richer'n stink at idle).
Questions:
1. Is manifold vacuum the correct way to run this carb?
(Cannot detect any spark knock with or without advance hooked up, even though initial is 20+ at idle.)
(MOTOR Manual shows a fairly mild stock curve. Will be installing CRANE Advance kit (springs and vac canister).
2. Any particular curve recommended? [This is an A/C car in hotter'n hell Texas].
3. Am looking to change to 5200-series carb, do any of them come equipped with EGR and PCV hookups, or will I have to modify carb and/or Clifford baseplate?
4. Am also looking to keep stock air cleaner/thermostatic system in place; any recommendations?
Thanks for any help. This is a great site, and this Mopar guy has learned quite a lot so far.
Questions:
