Valve covers: Just remember the torque spec for valve covers is 3 - 5ft lbs. If you snapped one off, you were
way over torque spec. I tighten mine using a 1/4" extension with a screwdriver handle, and probably still over torque them.
Here's a pretty good tip for removing a broken bolt - try a reverse twist drill bit. You have to drill a hole for the easy out anyway, and many times the bolt will come out while using the reverse twist bit.
Ignition: I've got to add some counter points on the D-II module failures. My understanding is the early versions of the modules were prone to failure, not so with later versions, but as Steve points out, my info is also second hand. However, I also have first hand experience with D-II in my 72 F-250. I'm running a D-II module in my truck that's almost 20 years old, and it's never missed a beat.
Key point is to mount the module away from heat sources - the one in my Falcon is mounted on the fender apron, as is the one in my truck.
Another point is cost - my complete D-II setup (distributor, wires, cap adapter, cap, wiring harnesses, coil, and module) from a pull and save place cost me about $25. Originality wasn't an issue to me, and that's the one thing I think the Pertronix has going for it. You can retain a stock looking igintion system with the benefit of electronic ignition and no one's the wiser.
The Pertronix is a good product, as are GM, MOPAR, and MSD units, but based on my success with readily available junkyard parts I can't justify the expense. It really amounts to what you expect, and how much you are willing to spend. For me, there was greater bang for my buck than going the route of MSD, Pertronix, etc.
Just offering another view...
