Hey all I'm considering swapping to an electric fan setup in my '63 Falcon (with a '68 200). I've searche and read quote a bit here, but here are my remaining questions:
1. how does the fan know when to turn on and off if controlled by a sending unit? I mean, I understand the principal obviously, but does it have it's own thermostat or does it tie into the one for the gauge? Does it just get wired inline for the gauge sender? FalconParts.com sells a thermostat housing neck with a threaded hole for a sending unit just for this purpose...should I spend the money on that?
2. I've read about using a relay to turn the fan on and off: positive battery -> relay -> fan switch (right?). So what do I ask for/look for when buying this relay? Are they "standard" or do I need a relay of certain characteristics? I'd also like to include an on/off switch in the car. Does this just act like a "sending unit bypass" of sorts?
3. Since I'm not overly concerned with the few HP I can gain by eliminating the fixed fan, if I have room for it, should I leave it in place or will a good electric fan be sufficient?
thanks as always!
thanks as always!
