MercuryMarc
I rebuilt my 1969 250 block and 1980 head on my 63 Comet. I have tried 6 carbs so far (yes I know I am a little bit crazy but I like to try to fix these things myself instead of handing them off to Pony Carbs, etc.). I have been tryning to get a smoother ride and a stronger top end so I have experimented a little (OK, a lot...).
1st carb: Holley 1940 (1 7/16th bore), Auto Choke. Ran fine, not much power a top end.
2nd Carb: Holley 1940 (1 11/16 bore), Maual Choke. Ran Fine, lots of top end power.
3rd Carb: Autolite 1101-could not get it to idle even after I rebuilt it- I suspect vacuum leak somewhere
4th Carb: HW 5200- from eBay then I rebuilt - terrible low range bog.
5th Carb: NOS HW 5200, always idled very rough, then it died.
6th Carb: Remanufactured Holley 1940 (1 11/16 bore), Maual Choke- this thing runs great! Smooth as silk idling, I can set the choke/idle speed with the choke cable every time I start it. This is the carb for me!!
So for now, I am sticking with the larger 1940. I think it was used for 240 and 300 ci truck engines so it should be able to handle the CFM needed for my 250.
Could it be that the other carbs were just too restictive for my 250?
Thanks!
Thanks!
