I found it NOS on ebay. I had to have the hub shortened by a machine shop as it was about 7/8" longer than the original one. It was listed to fit a 262 and it fit the crank diameter and key fine but the TDC was also off about 8*.peeeot":3hixi7mf said:Looks very professional!
Where did you source a dual-sheave crank pulley?
Daves55Courier":1g5bpmq1 said:In 1957 and later year 223 engines, the front right side of the engine casting was redesigned to include two mounting bosses for 3/8" N.C. bolts. The bosses were placed one above the other and a few inches apart. I never saw a '57 or later 223 that had anything bolted to those, but my guess was that they could have been used for A/C compressor mounting.
I actually have a factory add-on crankshaft pully that came off of a '59 223 that was used for the factory power steering. The pump was mounted way down low on the left side and piped up to a remote fluid reservoir. I could not see how they mounted it. I have a '58 223 and there is one in-used bolt hole at the left front side that might have been used for the lower ps pump brace, but I could not see how they mounted an adjustable stabilizer for the pump unless they used a longer bolt on the front exhaust manifold?
Is there enough room to unscrew the ps reservoir cap with your arrangement? looks really close to the alternator. Can you get the bottom radiator hose on the water pump? Is there room to get the vacuum line on the distrib vacuum advance can? I guess you are going to mount the ignition coil in an alternate location? Your brackets look really nice, but I would coat them with cold galvanizing compound at the very least so they wont rust.
garrilla said:Daves55Courier said:In 1957 and later year 223 engines, the front right side of the engine casting was redesigned to include two mounting bosses for 3/8" N.C. bolts. The bosses were placed one above the other and a few inches apart. I never saw a '57 or later 223 that had anything bolted to those, but my guess was that they could have been used for A/C compressor mounting.
I spent some time today trying to get the A/C compressor to fit the two mounting bosses down next to the oil filter. It would be a great location but there are too many obstacles (Lower Radiator Hose, Battery Tray or the V-belt hitting the Radiator Hose). The compressor does clear the Oil Filter housing but just not enough clearance elsewhere. Might work if an idler pulley could be rigged up to make the belt miss the lower radiator hose.
Daves55Courier":3cawwktl said:Oh, I see, now you are using that bottom hole for a stabilizer for the heavy end of the compressor. For a minute there, I was kinda scared that all that weight was cantilevered off those two little coil mounting bolts way back there. And I realize the belt is going to pull toward the engine, but still, it seemed like it needed more support. You know what would be great, is if you could have gotten another bolt there at the front in line with those two coil mounting bolts thru that long steel bar. There is a mounting boss on the head up there, but the factory did not drill and tap that boss. It should be okay with that bottom support I think.
Daves55Courier":3oghinpv said:I see you are using the little 54/55/56 water pump instead of the 57/58/59 pump which has a backplate and impeller chamber that sticks out the side. You probably would not have been able to mount the PS pump and alternator on that side if the 59 pump was there. So then I guess you drilled out the water bypass hole in the front of the engine block and tapped it for a little pipe plug ?
bubba22349":7rfgkgfn said:If you can post the Head and Blocks casting / design numbers and the date code I can help you narrow down the years of your engines parts. Good luck![]()
bubba22349":3myigaz2 said:If you can post the Head and Blocks casting / design numbers and the date code I can help you narrow down the years of your engines parts. Good luck![]()
