adjustable rocker arm bolt
I have found that i have one bolt that is backing off on my adjustable rocker arm. Is there any cars i could find at the pick u part that has that bolt? Or if anyone has a suggestion on what to try before i order a new rocker arm.
Thanks,
Nazs
Use some "lock tight" on the bolt. Some adjustable rockers have a second nut to lock down the bolt on the shaft.
check early fords with the 144-170 made from 1960-1964, i beleive. check Mustang-Geezers website, it has some part numbers. im going out to pick a part today, so ill look around for one.
Thanks for the info. Barroom let me know if you find something. I appreciate you looking for me.
Nazs
I just got a new adj. rocker assembly from napa with the jam nut style rockers. So far they work great! No more backed off screws!
Later,
Paul
Thanks everyone for the info. I will check Napa tomorrow. Thank goodness for this forum or i would not have gotten as far as i have with my engine :lol:
Nazs
Anyone happen to know the part # for the ajuster bolt at Napa? I called Napa and he said they dont have anything like that.
Thanks
Nazs
