adjustable vacuum advance?
I've got a 65 Mustang with a 200. I put a '68 dual-advance distributor with an Igniter II in it. The vacuum advance advances the timing 22 degrees. I have read that 10 to 15 is more normal. Is there an adjustable canister for this distributor?
Thanks!
Jerry
Howdy Back Jerry:
Wow!!! This is a trip down memory lane. I used a '68 distributor on my stock '65 200 back when I first got it, a long time ago. The 1st frustration was it didn't work well, at all, when the vacuum was hooked to the SCV source from the carb. I switched it to full manifold vacuum and too much advance at high vacuum conditions. The 2nd frustration was when I switched to a '68 Autolite 1100. It was down on power. FYI, the '68 & '69 Autolite 1100s don't have a SCV. They have a ported vacuum source, compatible with this distributor, but they are down 35 cfm due to a smaller venturi insert- 1.2" vs 1.1". I found an Autolite 1101 from a '69 250. It is rated at 215, up 30 cfm from a stock '65 1100, and no SCV but the correct ported vacuum source for the distributor. WOW!!! When all the parts work together it helps!!!
When you say that the vacuum advances 22 degrees are you including the initial advance setting in that 22 degrees? What are you using as a source for your vacuum to the distributor? What carb are you using?
This distributor is adjustible, but it is done by adding or removing washers, or spacers in the end of the diaphram housing rather than the Allen wrench as used on DS IIs. To access, remove the nut on the end of the diaphram housing. You will find a gasket for the nut you removed, calibrating spacers (washers). You may also have a spring with a stop inside of it come out, so be careful to not lose anything and put it back together in the same order.
To adjust, add or remove the spacers/washers. More washers/spacers decreases advance, fewer increases vacuum advance.
Thanks for the memory trip.
Hi David, glad to be back!
I'm running a 5200 carb. I used a MitiVac hand pump to test the advance canister. It starts advancing at 7" Hg and adds 22 degs by 17". That's just the advance, not including the initial. I've never measured vacuum at cruise on this car, but on another car, I measured 14". So I imagine it's up around 20 degrees advance at cruise.
Yesterday I curved the mechanical advance to 38 deg all in by 2700 RPM.
My canister was rebuilt, and the cover piece with the vacuum tube was replaced with a new piece which is crimped (or folded) on, The nut, washer, etc are all gone. It sounds like I need to find an original type canister if I want to adjust it.
