I'd like to do a ram air setup. I've seen the one that 'Geezer did. Super sharp, but I'm looking to do something a bit different. The way my engine bay lays out, plus the montecarlo bar and with the repositioning I did of the radiator (offset to the driver's side to allow larger electric fan to clear water pump pulley nose), I will need to use an air collector on one side only. Therefore, I want to run one duct. I think I can build the collector out of the same types of downspout components he used. It'll be on the passenger side, so my ducting will need to go essentially up 90degrees then turn 90degrees to the carb.
For the ducting, I really like the look of some of the chrome/polished hard-duct that the ricers are using vs the ole black flex-hose. I may try to make some fittaments with that stuff.
By 2 biggest issues are with the aircleaner and the connection on the carb itself.
The ricers are using cone shaped filters that are just hung on the end of the tube. Not really ram air. I need something that can be used inline OR right at the core support where I make my collector. Heck, if I could find an airbox with a filter in it that'd fit in my available space next to the radiator, that'd be perfect. I've got lots of height but it'd have to be narrow (like 6-8" or so) to fit between the radiator and battery tray.
Then, getting the "bonnet" piece that would fit on/over the aircleaner is my next issue. With the OZ intake offsetting the aircleaner so far to one side, I don't have much clearance for a big, round housing like Geezer used. I saw the thingy below in another post and contacted the guys. They said they aren't making them anymore.
http://img.photobucket.com/albums/v170/ ... oneair.jpg
That would proabably be perfect for what I need in the way of clearance. They also show these:
http://www.jameng.com/products/images/2748_offy.jpg
http://www.jameng.com/products/images/99010.357.jpg
If I could get one of those style adapters, I think I could clear my Monte bar ok.
Anyway, I was hoping to hear from the audience. What other ram air stye inductions have been done? What about a cheap supercharger/turbo setup (or if someone has a Paxton unit they wish to donate
Just fishing for ideas. I know there is no shortage of them here!
