Hi
Everything you need is here. Add machine work and you will have a might fine motor.
Bob
Product ID: PAK-200-PH1
Master Rebuild Package - Phase 1
Unlike other kits, you specify the bearing and bore sizes. Includes all the parts found in other kits plus a dual roller chain, stainless steel replacement valves, teflon seals, ARP stud & bolt kit, and optional rocker assemblies. All for a great low price.
Kit includes all of the following parts:
Seal Power Cast/Dished Piston and Pin Set
Pro Seal Plasma Moly Ring set
Clevite Main, Rod, and Cam Bearing Set
ARP Main & Head Studs, and Rod Bolt Set
Clay Smith Hydraulic Camshaft and Lifter Set
Matching Springs, Retainers, and Teflon Seals
SI Stainless Steel Replacement Valves
R.A.S. Chrome Moly Pushrods
JP Dual Roller Timing Chain Set
Corteco Master Gasket Set
Rocker Assemblies Optional
Please specify sizes and optional rockers when ordering.
Engine Size: Please Select...170ci 200ci 250ci
Bore Size: Please Select...Stock .020 .030 .040 .060 .080 (Seal Power only)
Main Bearing Size: Please Select...stock .010 .020 .030 .040
Rod Bearing size: Please Select...stock .010 .020 .030 .040
Cam Choice: Please Select...CSC-264-10-SHS CSC-264-12-SHS CSC-264-10-DHS CSC-264-12-DHS ARC-268-10-DHS CSC-274-10-SHS CSC-274-12-SHS CSC-280-08-SHS CSC-280-09-HHS
Rocker Assembly: Please Select...Stock 1.5 Non-Adjustable (+$70.00) Stock 1.5 Adjustable (+$90.00) HR 1.6 Adjustable (+$260.00) HR 1.6 Roller Tipped (+$410.00)
Email Friend List Price: $1,299.00
Price: $899.00
