TrickSix
I finally gave up on my original factory molded PCV hose, as the rubber was badly deteriorated. I have not seen any replacement hoses from the usual suspects. The straight piece of hose I put on works of course, but the routing is not so tidy. I found a little plastic right angle adapter used in some PCV.applications to put on the valve top. It helps a lot, but it's plastic, and being an add-on, it's taller than it would have to be. I see some PCVs for other cars at the parts store have the elbow built in, so it's steel and has a lower profile. Does anyone here know of any PCV that would be an appropriate flow rate, or spring pressure, or however they're rated, for a Ford 200 I6, that also has the 90* top and would fit in the valve cover grommet? Yes, there's a chrome plated one out there, but it might as well be gold plated for the price they charge.
